OEM factory rock sliders
<div class="bbWrapper"><blockquote data-attributes="member: 8518" data-quote="Russty__" data-source="post: 80317" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80317" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80317">Russty__ said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Ok, thanks. Is it possible to fit an actual rivnut tool up in there? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>This is the “tool” I got with my steps. Worked like a charm. Bolt washer and some bearings <br /> <a href="https://hdrams.com/forum/attachments/171dd927-7495-45e6-bd03-8e52fcb97bec-jpeg.15363/" target="_blank"><img src="https://hdrams.com/forum/data/attachments/15/15363-315e3b0890fbdb74319d59bd7070bed8.jpg?hash=MV47CJD723" class="bbImage " style="" alt="171DD927-7495-45E6-BD03-8E52FCB97BEC.jpeg" title="171DD927-7495-45E6-BD03-8E52FCB97BEC.jpeg" width="150" height="200" loading="lazy" /></a></div>
<div class="bbWrapper"><blockquote data-attributes="member: 7499" data-quote="Rockcrawlerdude" data-source="post: 80321" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80321" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80321">Rockcrawlerdude said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> This is the “tool” I got with my steps. Worked like a charm. Bolt washer and some bearings<br /> <a href="https://hdrams.com/forum/attachments/15363/" target="_blank">View attachment 15363</a> </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Ya I don’t have that tool but I have an actual rivnut tool. I’m gonna see if it’ll fit under there.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 8518" data-quote="Russty__" data-source="post: 80356" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80356" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80356">Russty__ said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Ya I don’t have that tool but I have an actual rivnut tool. I’m gonna see if it’ll fit under there. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Oh there is a bunch of room</div>
<div class="bbWrapper">Got them on, ended up just using the rivnut tool that came with the mounting kit I scooped from RAM. It was a PITA, mainly because I only have a 8&quot; ratchet, I think if I had more leverage It would of been easier. Also could only get 11 of the 12 smaller bolts that go through the pinch welds in. The last one was at a crazy angle I couldnt get the socket around. May mess with it tomorrow or might not, either way these things are super solid.</div>
<div class="bbWrapper">Use a 10mm nut driver for the smaller bolts and use anti-seize on all the bolts.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 4405" data-quote="jadmt" data-source="post: 80504" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80504" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80504">jadmt said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Use a 10mm nut driver for the smaller bolts and use anti-seize on all the bolts. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>You can tell you’re from a good ways north of where I’m from. I put blue loctite on all my step hardware and bolts. Lol no salt no rust down here</div>
<div class="bbWrapper">I had to use a wobbler extension to get the 10mm bolts out. <br /> <br /> Sent from my SM-N975U using Tapatalk</div>
<div class="bbWrapper"><blockquote data-attributes="member: 7499" data-quote="Rockcrawlerdude" data-source="post: 80509" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80509" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80509">Rockcrawlerdude said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> You can tell you’re from a good ways north of where I’m from. I put blue loctite on all my step hardware and bolts. Lol no salt no rust down here </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote> blue locktite works as anti seize as well. I use both liberally on anything that has threads <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" />. in the winter they use magnesium chloride for de-icing, nasty stuff for sure.</div>
<div class="bbWrapper">Much like the rock rails on the Wrangler Rubicon, I feel like these are a fail. Yes, I am sure they are better than nothing and probably function in a one dimensional aspect, but a far cry from what they should be. On my Wrangler, I am running ACE sliders which have a similar design as the White Knuckle ones with a primary tube along the body and a secondary tube that sticks out maybe 8&quot; or so. When off-roading, I hear &quot;clang&quot; and &quot;ting&quot; quite often as the front tires kick up rocks or sticks into the secondary tube which deflects it from the body. Also, if you are in an off-camber climb and slid sideways into a tree, the single tube design is almost useless. With the secondary tube design, you can use it to pivot off a tree or rock without smacking your door or panels on it.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 8393" data-quote="GeneralClortho" data-source="post: 80876" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80876" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80876">GeneralClortho said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Much like the rock rails on the Wrangler Rubicon, I feel like these are a fail. Yes, I am sure they are better than nothing and probably function in a one dimensional aspect, but a far cry from what they should be. On my Wrangler, I am running ACE sliders which have a similar design as the White Knuckle ones with a primary tube along the body and a secondary tube that sticks out maybe 8&quot; or so. When off-roading, I hear &quot;clang&quot; and &quot;ting&quot; quite often as the front tires kick up rocks or sticks into the secondary tube which deflects it from the body. Also, if you are in an off-camber climb and slid sideways into a tree, the single tube design is almost useless. With the secondary tube design, you can use it to pivot off a tree or rock without smacking your door or panels on it. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>probably depends on how hardcore you are. I have done most of the trails in Moab (go there 2X a year) with the exception of BFE, the rubicon trail, the dusy ershim all of the san juan Colorado trails and never had an issue. you can pivot with stock rubicon rails. Everyone has their own comfort level and I would be comfortable with these on all but the hardcore trails which it is going to be too wide for anyway..</div>
<div class="bbWrapper"><blockquote data-attributes="member: 4405" data-quote="jadmt" data-source="post: 80881" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=80881" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-80881">jadmt said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> probably depends on how hardcore you are. I have done most of the trails in Moab (go there 2X a year) with the exception of BFE, the rubicon trail, the dusy ershim all of the san juan Colorado trails and never had an issue. you can pivot with stock rubicon rails. Everyone has their own comfort level and I would be comfortable with these on all but the hardcore trails which it is going to be too wide for anyway.. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Good points all around. I will be picking up a set if my truck ever gets built and arrives. I guess it could be considered one of those mods that you may never use but when you need it, it is worth every penny...kind of like a winch. I had to go get help three times where a winch would have gotten me out. So, I put a 10k winch on my Wrangler and in 4 years, have never had to use it, lol...figures.</div>
<div class="bbWrapper">i would love for someone to post a video explaining how to install the 75ae steps. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" /></div>
<div class="bbWrapper"><blockquote data-attributes="member: 12101" data-quote="PW_SOCAL" data-source="post: 84553" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=84553" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-84553">PW_SOCAL said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> i would love for someone to post a video explaining how to install the 75ae steps. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" /> </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>do not take this the wrong way but it is so simple if you need a video you might want to pay someone to do it. Seriously if you can rotate your tires without cross threading a lug nut you can install the 75&#039;a steps. hold in place install bolts. I used a floor jack and two jackstands to hold it in place until I got 2 bolts started, one on each end.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 4405" data-quote="jadmt" data-source="post: 84563" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=84563" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-84563">jadmt said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> do not take this the wrong way but it is so simple if you need a video you might want to pay someone to do it. Seriously if you can rotate your tires without cross threading a lug nut you can install the 75&#039;a steps. hold in place install bolts. I used a floor jack and two jackstands to hold it in place until I got 2 bolts started, one on each end. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I agree. It’s one of those “if you have to ask” situations.</div>
<div class="bbWrapper">Picked up a set for 200 bucks, cost 140 to ship. Having a real tough time getting those rivnuts seated. Any help would be appreciated</div>
<div class="bbWrapper"><blockquote data-attributes="member: 4405" data-quote="jadmt" data-source="post: 84563" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=84563" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-84563">jadmt said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> do not take this the wrong way but it is so simple if you need a video you might want to pay someone to do it. Seriously if you can rotate your tires without cross threading a lug nut you can install the 75&#039;a steps. hold in place install bolts. I used a floor jack and two jackstands to hold it in place until I got 2 bolts started, one on each end. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>It&#039;s the rivnuts not seating properly is all, very simple install it seems like. those things are giving me trouble</div>
<div class="bbWrapper"><blockquote data-attributes="member: 7499" data-quote="Rockcrawlerdude" data-source="post: 84566" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=84566" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-84566">Rockcrawlerdude said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I agree. It’s one of those “if you have to ask” situations. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Well I don&#039;t really partake in shaming people for asking questions, but to each their own</div>
<div class="bbWrapper"><blockquote data-attributes="member: 12101" data-quote="PW_SOCAL" data-source="post: 84616" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=84616" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-84616">PW_SOCAL said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> It&#039;s the rivnuts not seating properly is all, very simple install it seems like. those things are giving me trouble </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>just torq the tool to about 25 ft/lbs and they will seat. they hole is a hex and the rivnut is a hex so they won&#039;t spin.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 4405" data-quote="jadmt" data-source="post: 84621" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=84621" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-84621">jadmt said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> just torq the tool to about 25 ft/lbs and they will seat. they hole is a hex and the rivnut is a hex so they won&#039;t spin. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Thank you</div>
