Unless you pay extra for the uv coating from line x it fades just as fastI had the factory liner in a 2014 1500, no tonneau cover. It seemed like it faded really quick.
Wonder if the caps could be sprayed?The bed rails are perforated with holes for the plastic bedrail cap cover clips.You could pull them off but unless you do bodywork, the holes will be there.
I bit off the topic, but it does concern the bed rails. Although my new 3500 should be delivered early next week (ordered February 24th), I have never seen a 2021 in person. I will be installing my ProTech toolbox as soon as I get the truck. I had it mounted in my 2004, and want to use the same mounting method. The only "through-bolt" attachment occurs along the top of the bedrail at the front of the bed. This is the rail that parallels the cab. The side attachments are done using blind rail clamps, and I know those will work on the new truck. I do need to drill three holes along the top of the rail behind the cab. My question is, does this rail have a plastic cap like the side rails? If it does, how is it attached? I assume it would be attached with clips of some sort. Ideally, I would remove the cap and bolt directly to the rail. I'm afraid that attaching on top of a plastic cap would cause issues in appearance from compressing only portions of the cap. If I remove it, if it has one, how many holes would be visible from the clip locations?
If anyone has a closeup picture of the front of the bed, that would be greatly appreciated.
Line-X has a target of 120-125 mils and my factory bedliner appears to be in that range. My 2002 Jeep had the interior coated in Rhino Liner when it was brand new and it was probably double that thickness which resulted in fitting issues when reinstalling the roll bars and other components.
Mil = thousandth so that would be .12 inchWhat do you mean by 120 mil?
LineX color match spray in liner. Delmonico Red. Love my truck. And kudos to LineX for the great job they did.
How long before it turns pink? I had a friend with a pink bed Chevy. It faded in the Florida sun in 3 years with the coating to supposedly preserve it.LineX color match spray in liner. Delmonico Red. Love my truck. And kudos to LineX for the great job they did.
I don't think it will. I have a buddy with the color match thats had it about 4 years now. Looks the same as the day they sprayed it. Not to mention that most of the time my tonneau cover is closed, so it won't be getting much sun. I just don't understand this overall fascination with everything black. Vehicle interiors, black out packages, spray in liners, etc... I mean to each their own but thats just dark and depressing. I prefer vibrant colors that pop. I like things to be light and airy!How long before it turns pink? I had a friend with a pink bed Chevy. It faded in the Florida sun in 3 years with the coating to supposedly preserve it.
