Awesome. How do you access your clutch though? The Power Wagon has an extended clutch handle next to the fairlead, but even that is a pain to reach sometimesI did the PW winch install.
Considering the duty cycle on that winch your alternator would be more than enough if you followed the proper winching cycle according to the duty cycleYes mine does this as well, I think it idled up to maybe 1500rpm or so, but it was not keeping up with the electrical load from the winch, as the voltage was dropped below 12V. The Warn Zeon 12-S can pull up to 470amps at full load...
What’s the duty cycle? Warn makes no mention of a duty cycle.Considering the duty cycle on that winch your alternator would be more than enough if you followed the proper winching cycle according to the duty cycle
Glad I have the 100’ winch lineWhat’s the duty cycle? Warn makes no mention of a duty cycle.
But the point is, the winch draws a massive amount of power at high loads, and the electrical system will struggle to keep up with it. Solutions: Let the winch rest often to let the electrical system catch up. Reduce load by increasing mechanical advantage(switch to a 2:1 or 3:1 system), or reducing more factor(bust out the shovel). Upgrade alternator.
Sample electrical load calcs for how long it takes to drain the battery when winching...
Someone check my math.
i have 65ft of line on my winch, ~50ft useable after the first wrap. Stock alternator is 180amp , but produces about 160amps at 1500rpm engine speed. (For reference the 220amp alternator produces about 200amps at this engine speed). Looks like H7 is the battery for our truck, which seems to have a reserve capacity of 140 minutes (time to “discharged” with 25amp load). We will ignore any other electrical loads for the sake of simplicity.
If I pull all 50ft without rest, with a 6000lb load , it will draw 272amps for about 6 minutes(7.8ft/min).
272amps-160amps =~ 110amps, which is roughly 4x the “rated” load for reserve capacity. So at this rate the battery would be discharged in 35 minutes.
Now if we’re pulling at the grill capacity of the winch, 12000lbs, using 469amps. It will take about 15 minutes to pull all 50ft(3.3ft/min) line speed.
Our power draw 469amps-160amps=~ 300amps, which is about 12times the reserve capacity rated load(25amps). Battery will be discharged in 12minutes...
I keep a short line, and carry an extension and an x-lock. Short line is quicker and easier to respool, and less line means gets you down to the lower layers for more powa.Glad I have the 100’ winch line
More line = snatch block = less Amps (;I keep a short line, and carry an extension and an x-lock. Short line is quicker and easier to respool, and less line means gets you down to the lower layers for more powa.
My warn is about 7% so i will winch for 1 min at max cap or 2 mins at 1/2 cap let rest for 1-2mins then go again this is the winch i ran on my old jeep with a 100 amp alt i would strongly advise running extra cable and a snatch block you could greatly bennifit from dual batteries if you are doing that much winching constantlyWhat’s the duty cycle? Warn makes no mention of a duty cycle.
I rarely used my winch i would typically just hook a strap and use the jeep to pull others it was faster for me personally you just have to be more careful and easy on the skinny pedalNot going to lie, on the trail when someone has rolled or broken something, duty cycle never crosses my mind. I’m not even going to pretend I let it rest. The warn on my Toyota gets abused on a regular basis, long constant pulls, only allowed to cool off while we reset the rope or move a rig. I know that ain’t right but I’ve never had a Warn let me down or quit.
Because of the heavy load nature, I wanted the thermal monitoring of the 16.5ti for the Ram. I ordered a 16.5ti for the Ram back in Nov but warn said the ETA was April or longer and there were none in the country. AEV co-signed on this, saying they wanted to offer the winches for sale with their bumpers, but they are having trouble even getting the winches for their upfitter vehicles. I had to settle for a M12S to get me up and running, but is has the longest cable of the heavy duty Warn options, so double line pulls will be easy and likely the norm
^ always the first optionI rarely used my winch i would typically just hook a strap and use the jeep to pull others it was faster for me personally you just have to be more careful and easy on the skinny pedal
was it just a drop in and go? Or did the ecm need a flash?56029644AB
Plug and play, no programming needed.was it just a drop in and go? Or did the ecm need a flash?
Took the day off to work on my truck.
Had to make a decision of installing shocks in the rain or putting the Toyota out in the rain.
I decided I would be grumpy if I was working in the rain.
They’re great, as usual. I love Fox, that’s what I run on pretty much everything and am set up to service and tune shocks at home and have the knowledge to do so. Disclosure: my brother is an engineer at Fox, but I do have to pay for my shocks.How are the Fox shocks working out? Have you driven it enough to tell?
These are “cheaper” Fox, but anytime you swap out a set of emulsion shocks for a set of shocks with internal floating pistons, you’ll see a difference. Even more of a difference when you bump up to a reservoir shock. A properly tuned resi shock makes a world of difference. My Toyota has been described as “rides smoother off road than my Jeep rides on road” by passengers
There are lots of great shock options out there. Some higher $ and some lower $
I have an unused level spacer kit for sale cheap (; see classifiedI like Fox shocks. I have Fox 2.5s on my 2007. I have Kings on order from Carli for the 2020. I ordered them in October and it still looks like I am 3 months out. I found a good deal on some tires and I thought about picking up a quick level kit to run in the meantime.
That is a good deal. I am told 37s will fit on a stock truck with the same pinch weld/liner mods you need to do with the 3" lift anyway. I am sure it will look like butt without the level though. Hmmmm....I have an unused level spacer kit for sale cheap (; see classified
