Well, after weeks of research and debating I decided I’d try and run 37’s on my stock 2019 2500 Laramie diesel. Went with Fuel Blitz rims 20x9 +20, and Toyo AT3 37x12.5r20. Got a great deal from #discounttire. They test fitted one front wheel as they said they would not fit. It rubbed slightly on the back fender liner. I went home and trimmed the plastic, ground down the pinch weld about a 1/4” and zip tied the liner back. Total trim job took less then 20 minutes. Went back and had them install the wheels. Wheels fit perfectly.
Illl run this until I decide if I want the Thuren +1” front, -1/2” rear setup for a softer ride.
Happy with the AT3’s too. Look aggressive and are smooth and quiet. Running them at 55 psi fronts, 53 psi rears.
