mlink
Mine had the rear wheel speed sensors replaced Friday. Saturday I drove from CT up to ME with no incidents & shut off/started up a bunch of times. It feels fixed - but I’m still wary…
Above from another thread here...dealer "fixed" it about a month ago by reflashing but according to paperwork they didn't even write down the correct problem.I have had this 3x on my 2025 3500. First time I noticed was after window tinting. Shop claimed all those lights (speed sensor related...Those mentioned above and park sense and no cruise) were on when they got in it. Disconnected batteries to try the old middle finger electrical salute. Didn't work. Whatever... Was near dealership so headed that way. A jaywalking moron forced me to slam on brakes and all but CEL went off. Dealership pulled codes and only one was P2509 from me disconnecting batteries. There was a TSB for that so they reflashed it. In and out in 45 minutes.
Last week hit a chug hole right before I parked and shut down truck. Restarted and Christmas tree again with speed sensor type stuff. Off then back on and CEL with all the speed sensor stuff. Drove a little bit and slammed on brakes...all lights cleared. Got home and hooked up code reader (U1412) and cleared CEL.
Yesterday was on way home, and dash lit up again. Tried several hard brake cycles. Nothing. Shutoff and restarted(CEL appeared)...2 more hard brakes. Lights stayed on. Then miraculously all lights went off with normal driving. Got home and U1412 again. Cleared it.
Have appt next week at dealer.
Has your truck been working now?After months of waiting and anticipation, I finally picked up my brand new 2025 Ram 3500 DRW truck on Wednesday. I had driven up from the Florida Keys where we are currently staying to New Hampshire where my dealer is located to take delivery. The next day I was driving it back down to the Keys and around the 500 mile mark I started getting a lot of warnings and errors on the dash display. ABS light, stability control light, collision sensor lights, and cruise control light came on as well as messages saying to service these items and that Four Wheel Drive is temporarily unavailable. Cruise control no longer worked either. After I stopped for fuel, the lights went off but the check engine light stayed on. I stopped for the night at a motel and the next day of driving the check engine light was still on but then I stopped at a rest stop and restarted it and then that light was off. I thought all was well until not long it did it all over again. This happened several more times on my down down to the Keys. I’m now down here and the check engine light is still on. I do have an appointment with a local dealer down here to get this looked at and hopefully corrected. I sure hope this isn’t a sign of serious problems with this truck. Not sure if it is related but also the unlocking of the door by grabbing the handle while the fob is in my pocket is hit or miss. Sometimes it works and other times the only way to unlock it is with the button on the fob. Needless to say I’m a little upset about all this.
I have seen 3 fixes for this issue:
bad wheel speed sensor
Bad RFHub
Computer reflashed/Updated
Where might I find the canbus hub?
There are no canbus hubs on the 2025’s. Completely different can architecture. The modules are daisy chained together on several different can networks that all originate at the security gateway.Where might I find the canbus hub?
So this could be a long wait - if at all - for any aftermarket options to add features/change settings.There are no canbus hubs on the 2025’s. Completely different can architecture. The modules are daisy chained together on several different can networks that all originate at the security gateway.
Thank you for sharing this. Keep us posted if anything changes. I’m going to reference your case when I get around to taking mine in.My dealer fixed this.
Star Case #: S2523000055 pointing to replacing Wheel Speed Sensors in rear. Replacement Parts needed: 68646344AA (Right Side) and 68646345AA (Left Side).
After parts replaced, I drove from CT to Bar Harbor, ME and back (about 750 miles) with no incidents or CEL. First time ever...
Hope this helps.
Mine hasn’t given the error in over a month now and we are towing a 46’ 5th wheel across the country. The last time it happened was when we were in the Florida Keys and we are now in Tombstone, AZ and it has yet to throw those errors. We did however have a check engine light come on with no other messages but after a day of driving it cleared itself. There are obviously still issues that need resolved but since we are traveling I’m not sure how to get it taken care of, especially with it not really happening anymore.So has anyone actually had their truck fixed? and it stayed fixed? No repeat issues?
Since my original post my truck has been back in the shop 3 times for the same issue with nothing found yet. Today I get a call that they have ordered new wheel sensors because they had read that this is a possible cause of the intermittent electrical issues. While had them on the phone I mentioned to them about the fuse issue and asked them to check. The wheel sensors are on back order and will not be here until mid August??? I the. Went and picked up my truck. Once home this afternoon I checked the fuses myself and of course found 20+ fuses and the relays not fully seated. Some of the fuses were approx. 3/16” higher than the same fuse next to it. I sincerely hope that this is the fix of these intermittent electrical issues. I keep everyone updated over the next few weeks.I purchased my news 2025 Mega Ram 3500 and within 12 hours experienced the same. It started with a warning that the traction control and ABS was not working, then the emergency brake warning was lit, then received a warning that 4X4 was not available, then check engine light and then when attempting to turn off engine I received a notice that the truck was not in park and it would not shut off. No matter what you tried it would not shut off. If you tried to put it in to gear it stayed in park and would not move. Called the dealer and they only had folks there on Saturday to do oil changes??? No one there capable of working on a diesel on Saturday. While attempting to get support the truck was running for several hours and could not be turned off. Their only guidance was to GOOGLE a YOUTUBE video to see if there was any information online. Finally, I pulled the 25 amp ECM fuse to shut it down. I then attempted to read the codes with a reader and had no codes??? I then started the truck again hoping everything had reset. No luck had to pull fuse again to shut off the engine. Sixteen hours after spending a fortune it was then towed away. Waiting for Monday to get an answer on what happened. Totally unsatisfied customer!
My fuses were the same but I had the same issues even after seating them all.Since my original post my truck has been back in the shop 3 times for the same issue with nothing found yet. Today I get a call that they have ordered new wheel sensors because they had read that this is a possible cause of the intermittent electrical issues. While had them on the phone I mentioned to them about the fuse issue and asked them to check. The wheel sensors are on back order and will not be here until mid August??? I the. Went and picked up my truck. Once home this afternoon I checked the fuses myself and of course found 20+ fuses and the relays not fully seated. Some of the fuses were approx. 3/16” higher than the same fuse next to it. I sincerely hope that this is the fix of these intermittent electrical issues. I keep everyone updated over the next few weeks.
I had a 2022 2500 and had to push the fuses down after reading about them here.. I immediately checked them on the new truck when I got it and pushed them down. All issues I’ve had have been after the fuses were seated properly.Since my original post my truck has been back in the shop 3 times for the same issue with nothing found yet. Today I get a call that they have ordered new wheel sensors because they had read that this is a possible cause of the intermittent electrical issues. While had them on the phone I mentioned to them about the fuse issue and asked them to check. The wheel sensors are on back order and will not be here until mid August??? I the. Went and picked up my truck. Once home this afternoon I checked the fuses myself and of course found 20+ fuses and the relays not fully seated. Some of the fuses were approx. 3/16” higher than the same fuse next to it. I sincerely hope that this is the fix of these intermittent electrical issues. I keep everyone updated over the next few weeks.
Any additional updates? I now have this exact problem with a 2025 3500 DRW.Mine hasn’t given the error in over a month now and we are towing a 46’ 5th wheel across the country. The last time it happened was when we were in the Florida Keys and we are now in Tombstone, AZ and it has yet to throw those errors. We did however have a check engine light come on with no other messages but after a day of driving it cleared itself. There are obviously still issues that need resolved but since we are traveling I’m not sure how to get it taken care of, especially with it not really happening anymore.
I am right there with you except they had my truck for 34 days! Only had 1500 miles on it. Got it back and it is now making a random scratchy noise in the dash that goes thru the speakers, I have reached out to the dealership and am nervous it will be another long slow walk out of the shop as I really don’t think they know how to get these trucks truly fixed! At this point I’m thinking buy back!I purchased my news 2025 Mega Ram 3500 and within 12 hours experienced the same. It started with a warning that the traction control and ABS was not working, then the emergency brake warning was lit, then received a warning that 4X4 was not available, then check engine light and then when attempting to turn off engine I received a notice that the truck was not in park and it would not shut off. No matter what you tried it would not shut off. If you tried to put it in to gear it stayed in park and would not move. Called the dealer and they only had folks there on Saturday to do oil changes??? No one there capable of working on a diesel on Saturday. While attempting to get support the truck was running for several hours and could not be turned off. Their only guidance was to GOOGLE a YOUTUBE video to see if there was any information online. Finally, I pulled the 25 amp ECM fuse to shut it down. I then attempted to read the codes with a reader and had no codes??? I then started the truck again hoping everything had reset. No luck had to pull fuse again to shut off the engine. Sixteen hours after spending a fortune it was then towed away. Waiting for Monday to get an answer on what happened. Totally unsatisfied customer!
