Anyone know how to REMOVE the sgw bypass?
The instructions say to gently pull the connect while depressing the tab of the connector.
That photo doesn't make any sense. It looks like they're pressing from the female side, which is obviously plugged into the block.
Mine doesn't seem to be working now and I want to test the wires. If I plug the Vlinker into the OBDII directly, it immediately lights up. So either I've got a bad connection, or a short in one of the wires of the bypass. If I can take it out I can hit it with a multimeter to see where the problem is, but I can't get it out.
Any tips?
Yeah, that sounds like the easier method.Cut the little locking tabs off once you get them out. Makes removing them far easier.
Hello Brutal, I have a 2023 Ram 3500 and would like to reset the threshold tire pressure alert limits. I do have an AlfaOBD and the bypass cable. What exactly does need to be reset in the AlfaOBD? A certain code or what? ThanksWhy don't you just get setup with AlfaOBD or Jscan and set the threshold to whatever you want and/or turn the TPMS off (set to TPIS)?
Assume you have already activated the TPMS. Go to adaptation and search for "tpms". Go to TPMS Settings. Set light load for front and rear to 0 and the max load to whatever you want. I set my front to 65 and my rear duals to 35. I use the door sticker values when I tow the fiver.Hello Brutal, I have a 2023 Ram 3500 and would like to reset the threshold tire pressure alert limits. I do have an AlfaOBD and the bypass cable. What exactly does need to be reset in the AlfaOBD? A certain code or what? Thanks
So, I was being stupid, everything works just fine. It helps to plug the harness into the OBDII, not just the security plugs. Wow. Sometimes I over think things and miss the obvious. Oh well, at least now it's really easy to remove from the truck when not in use.Anyone know how to REMOVE the sgw bypass?
Any tips?
What about 18? I have JScan and have lowered my threshold, cleared codes , and still have low tire light on.PIN is not needed for 19+
