*Breaking News* 2025 Orders from MARK DODGE **
It's in the Max Tow package. All the contents priced seperate added up it is cheaper than 2024.
It is for the Laramie and limited but not for the Big Horn:
MAX TOW PACKAGE (AJL)
+ 3 REFLECTING TRIANGLES (XWH)
+ 5TH WHEEL/GOOSENECK TOWING PREP GRP (AHU)
+ CTR STOP LAMP W/CARGO VIEW CAMERA (LPD)
+ DOT FIRE EXTINGUISHER (XFY)
+ SPARE FUSES (XFG)
+ TWO RED VINYL FLAGS (XD7)
+ SPARE FUSES (XFG)
I want a Megacab so this is not an issue for me. If you want a Bighorn then maybe ask Anthony to check in VOIM and see if it can be ordered that way, with the air suspension. I would not personally get one of these trucks without it.
Hear Ye Hear Ye!
Late this afternoon we got the order guides for the 2025 HD Ram lineup!
Appreciate the update.
If and when any updates on the 2025 chassis cab codes pass through to you, I’m sure there’s at least a couple of us on here that’d be all over that info.
Cheers.
I have a 2024 Big Horn on order (with auto leveling) so this is more for my curiosity or if something goes wrong with my order. I'd actually prefer a Laramie but I couldn't get one with a gas engine.
Also, a Megacab is another thing I didn't see in the order guide, are they listed in another guide?
Are they not offering delmonico red on the 25's? I'm not seeing it on the option sheets. That's my favorite color :(
+ SPARE FUSES (XFG)
It also looks like you can only order the auto level rear air suspension on the 3500s with the 8 ft beds. Not showing available for the short beds. And only for the Limited or Laramie. If they can put the auto level rear on the 2500 short beds, why not the 3500 short beds?
How does it work when the same option is listed in two different places? Like LPD the CTR STOP LAMP W/CARGO VIEW CAMERA is listed under the Laramie Level 2 plus equipment group, but also as an option again in the Towing technology group?
Cheers.
just checked I don't see it there yet, I did just ad the Single (regular) cab guides I think I've ordered maybe 3 of those in the last two years though :)
that would mean you can get it as a standalone option OR it would come in one of those groups.
For that item you could get the CTR stop by itself.
Or you could get the L1 and add tow tech
Or you could get L2 plus and get the whole shebang
There is only one option as previously rumored. The HO is gone. The base engine is 430/1075 mated to a ZF Powerline with a column shifter. Grid heater is gone, replaced by glow plugs. Topside oil canister housing and both primary and secondary fuel canisters/filters mounted on the engine. There's a new combo DOC/SCR and EGR system.
eww column shift but at least it’s a zf now. Did they go back to iron block as well? I wasn’t too confident in the new graphite block or whatever it was
BI-FUNCTION LED PROJECTOR HEADLAMPS (LM6) as standard on Laramie & Limited/Longhorn
On my '22 Limited this (bi-function projector) is what showed on my build sheet. Is the "bi" part of it the fact that they turn with steering? Or something else? I thought it would be super gimmicky but I have quite liked it out in the mountains at night.
Pretty exciting updates, although some better than others.
One diesel engine choice is smart.
Anyone have any details on the new HPFP?
