How many quarts of Yuengling does a 6.4 take?
Decided to do an early oil and fuel filter change since my confidence in the dealer I bought it from was low even though they claimed it was all done before it hit the lot. Seems pretty clear this rear fuel filter was not changed the same time as the front.
The rear is primary and typically looks like what you’re seeing.
Installed NH Overland RAM HD Upfitter Terminal Block Mount
Cover Off_________________________________________Cover On
Really happy with this purchase, easy install and looks great. I have my CJC/Baja Designs Fog lights on switch one and my ham radio on switch 2. I'm still in the process of mounting the radio in the cab. Lower center stack is tore out of the truck at the moment, ran out of time this evening. Not pictures I have a fender mount with a 1/4 wave 2m antenna mounted.
If @NHOverland is interested in a suggestion, it'd be nice if the positive block used 2 short screws to keep it in place when the cover is off(there are 4 holes available). As is, the screws that hold the cover down also hold the block in place. Not a deal breaker, I put the screws in without the cover as I was hooking things up.
I was having a hard time seeing what the cover plate looked like on the term. Im not overly concerned about water but it looks like short of blasting with a hose it should be water resistant enough? I ended up getting it , then this site was down lol
It's not water tight, the cover is just to avoid shorts in my opinion. It doesn't need to be water tight if you use the right crimps. I used marine type crimps that have glue in the heat shrink. I'm really happy with it, extremely high quality.
