Thorvald
Just had this happen over the weekend heading out camping. Truck was at 40% or so DPF full on EVIC, automatic Regen started. Just a few moments later it went to 60%, 75% and then bam 100% DPF Filter full message and of course Regen stopped. Thankfully the reduced power was still more than enough to pull the trailer just had no passing speed. Truck is booked in for service but that is over a week away.
I’ve had a Koadtech bypass cable and LX Odb cable in the truck since new so figured this was a good time to buy AlphaOBD and force a Rege… Well that was $78 dollars down the drain, would not force a Regen as not all parameters were met (though I wish it was like the dealer tool that tells you which parameter was not met), I suspect the PDF full DTC code since it could not be cleared.
Next ordered CTS Edge 3 from Amazon as it has been in my basket since the truck as new as well. It arrived, connected it up and selected anything to do with DPF under basic and advanced pids. Strangely got basically zero readings when truck was running or driving, so either when DPF is truly full the sensor reads basically 0 pressure (I would assume it would read too much back pressure) or the sensor is kaput.
I’ve previously has two CEL codes for DPF sensor back at 14,000km (65,000 km ago) so I suspect it’s yet another bad DPF sensor.
Can anyone else with an Edge 3 confirm what these values “normally“ look like? @John Jensen perhaps?
Thanks
Tim
Thanks
Tim
