2019-2022 Dually largest oversized tire on stock wheels/truck?
looks good, running any spacer in the rear?
No spacers, but running 2020 ford inners (17x6.5") which have a slightly higher offset. +6mm additional offset (IIRC). Same bolt pattern/hub bore. Going to replace the night edition rims with some aftermarket 6.5" wide rims eventually.
Just ordered the 7 of the AT3's from Tire Buyer, $17.50 off per tire ($70 of 4 but this is how it applied), plus 12% off installation, plus an AMEX reward for $45 off $300 or more.
Discount ended up basically covering sales tax and install.
AT3's installed today after a bit of a delivery debarkle, look good on my rims (I have the OEM's power coated satin-black).
@ParallaxReign people have gone upwards of 275/285 wide with a 2" spacer, but your about 1-1.5" short of the recommended rim size, so YMMV
Weather is pretty meh today, but here you go. I know it doesnt *require* a spacer, but I'm planning on putting a 1/4" on on the rear, it arrived today but was for a 154mm hub bore not 142mm so is getting returned.
Is everyone changing out their spare to the same size or would the stock size be ok in an emergency? 255/80/17
That is stock, no spacer. the 1/4" spacer arrived, and opted not to install
Just got back from putting ~7,000 miles on the Toyo's in 3 weeks. Tires ran flawlessly. Mostly towing ~8,000lbs. Some offroading, terrible i10 potholes, hitting some hard-to-spot tree stumps on the sidewall and performed really well. Was a little hesitant with the "non-recommended" wheel size, but have been very impressed.
View attachment 57603View attachment 57604View attachment 57605
Just to confirm, these images show stock wheels, stock suspension, no spacers and the “Toyo Open Country AT3 in LT255/80R17”size you mentioned in an earlier post?
Looks really good!
Probably the route I will go once I burn up the factory tires
Correct, stock wheels (just powdered coated satin black), Stock suspension (Ram Airbags in rear) and no spacers with AT3 LT255/80R17
Got a new tire size for the stock wheels boys. Kenda Klever in 35x10.5r17. I think they look amazing!
I added these along with a Carli 2.5" level, some 2" rear blocks and airbag spacers, and Bilstein 5160 reservoir shocks up front with 5100s in the rear.
Completely transformed the truck. LOVE IT.
Here they are with no rear spacer.
I didn't like it so I added a .25" spacer and now im comfortable with it.
Is anyone adjusting their speedometer with the 255/80/17’s or just leaving it as is? Looks to be about 2-4 miles per hour off.
Mine is 5mph off with the 35's... Im going to adjust mine with the Edge EZX.
  • Like
Reactions: CFE
