John Jensen
Thanks, I get it, your statements are not based on fact, they are really a result of how you feel.In our bunch theirs 6 ram trucks, 2 3500 HO trucks, 2 3500 standard trucks, 2 2500 standard trucks.
Mine is one of the HO’s and if you’ve read the post you can see what mine does. The nephews is the other, he drives the crap outta it, tows heavy 75% of the time, regens daily, uses 5 gallons of Def a month.
The other 4 are standards and hardly ever have gauge movement and don’t really know if they regen or not but they have to because they add Def but no where near what we do.
I do feel the HO trucks produce more soot then the standard because of how the engine produces the extra horsepower with internal parts and programming.
Being the HO’s are the best when it comes to fuel efficiency how do you know if a untuned truck is giving a clean burn? Only thing that comes to mind is regeneration frequency.
As far as tuning I can see that giving a cleaner burn and reducing soot. I’ve went as far to ask edge and stealth both if they seen less regens when adding their products and they have no answer probably because they didn’t figure that in when testing the product or lack there of testing.
Now after talking to those to I did talk to Kory at PPEI and he in fact looked at soot build up and regeneration. He sees less regens by 50% and minimal def usage.
Again I wish Ram had incorporated a egt screen after going through the trouble to let you monitor the dpf.
Yes I can add a CTS3 and will when I delete the emission.
I did read your posts and they tend to confuse me. For example, here in your first PP, you say they must be regening because they are using DEF. That makes no sense. The SCR system controls DEF usage. The DPF system controls Regens. They are separate systems and have no relationship other than both being part of the emissions system.
I don't mean to be critical or argumentive, just trying to understand why you say what you say.
Hoping you get things straightened out. Cheers!
