My TIM said Made in China on it.
Sorry, true. Made in China by a UK supplier. Both outer bags indicated UK. My TIM says Made in China on the box too.
Do you have any closeup shots of the bags? Didn’t keep mine.
Got it, interesting, globalization is funny sometimes. So if we knew the UK vendor, the thought would be a generic made by them might work? Do you have any closeup shots of the bags? Didn’t keep mine. I like that pressure vessel idea because I could try a few without installing and be able to return them.
This particular post should be a sticky. For those that haven't been following this thread and looking for this information, it will save quite a bit of time searching.It's been posted several times through the thread and initially summarized by @thestuarts here.
Since we can't seem to get the OP or a mod to post the part numbers in the first post, here they are again:
PARTS REQUIRED TO ADD TTPMS to 2019+ RAM HD TRUCKS
TTPMS bumper receiver: 68375990AC (Avg cost ~$70)
TIM headliner module: 68404893AB (Avg cost ~$70)
TIM Pigtail cable: 68412666aa (Avg cost ~$9)
The kit for the TPMS sensors (4) for trailer wheels is 68433188AA (best price I've seen posted not too far back in the thread @ $146)
Most of these parts are currently out of stock everywhere thanks to this thread.
You will need to install the hard parts. @Phil T excellent instructions pdf here.
You will need to have the sales code option enabled by the dealer (unlikely) or use AlphaOBD, an ELM327 Bluetooth OBD2 reader, and a security bypass cable (KaodTECH recommended) to recode the BCM. There's a giant AlphOBD thread here.
Turning on the TTPMS option in the EVIC thanks to @g00fy : https://hdrams.com/forum/index.php?threads/tpms-tis-sensors-for-trailer.232/post-20366
For the 2019 trucks, you will need to use the Windows version and select the MY2020 under advanced - also thanks to @g00fy
He also suggested enabling "P/T chassis net: TTPM" Which I also did. Unsure if this matters but it didn't cause any problems I'm aware of. The TTPMS setup docs may indicate that this is necessary:
"The TTPM sends the information to the TIM via the Controller Area Network-Chassis (CAN-C) to be transmitted to the IPC."
Really need somebody who has the option from the factory to give us a log and their Vin so we can compare settings and find out exactly what extra hardware we need (if any). I also wonder if, like the brake controller, there's an extra controller box that's required and not showing in the...hdrams.com
Does anyone have a copy of AlfaOBD version 2.1.8.0? @Phil T wrote his instructions for that version, but version 2.2.0.0 is what is currently available. I can't get AlfaOBD version 2.2.0.0 to commit the TPM setting change. I have the kaodtech security bypass installed, and I can see all of the settings, but it fails to write every time.
You're using the Windows version?
If nobody comes through by Monday afternoon, I’ll be able to send you the file. I haven’t updated yet.Yes, registered Windows version 2.2.0.0.
More and more lately, it seems like every update for both versions, something “breaks” on one or the other. Next update, there’ll probably be an issue with Android version.I am replying to my own question with an update.
I should have checked this first, but I was actually able to enable the "VehConfig 8-Trailer TPM" and "P/T chassis net: TTPM" settings with my Android version of AlphaOBD version 2.1.8.0 connected to an OBDLink MX+ using the Body Control Module MY2019 configuration.
I didn't need to use the PC version of AlphaOBD, and I didn't have to spoof MY2020.
I believe there is a problem with AlphaOBD version 2.2.0.0 because it can't read all of my system IDs like version 2.1.8.0 can.
