Undecided1719
Ok so bought a new 2020 Ram 2500 December 30, 2019. Got 7023 miles with CP4 failure. Guess I should have done better homework.
Interesting read. The OP of that other thread sates, more then once, that Cummins is picking up the tab. There's no way in HE double-L that he or she is gonna know that. The engines belong to FCA, lock, stock and barrel. If there WAS a quality issue at Cummins, FCA would be dealing with that and those deaalings would be transparent to a Ram customer.Same guy posted on ramforum. A bit more than posted here, but short on details, for sure. If it's really happening I'd like to know about it, but trolls are out there, too.
2020 Ram 2500 CP 4 Failure
Ok so I bought a new 2020 Ram 2500 in December 30, 2019. Got 7023 miles on it with a Cp4 failure. Guess I should have done better homework.www.ramforum.com
Not designed for diesel fuel used in the US? This is bizarre, let alone hard to believe. How long has this particular pump been used on these trucks?I just noticed this on another forum:
In the above link they mention:![]()
Bosch CP4 High-Pressure Fuel Injection Pump Failure Lawsuit
Our attorneys are evaluating claims that the Bosch CP4 high-pressure fuel injection pump installed on some American made diesel powered cars, trucks, and SUVs is failing prematurely because of a defect. Consumers shouldn’t have to pay for the repair costs, but some manufacturers aren’t honoring...www.forthepeople.com
Why Is the CP4 Pump Allegedly Failing?
The primary reason the CP4 pump is said to fail is because the pump was not designed for diesel fuel in the United States.
Bosch is a European company, and Europe uses diesel fuel with more sulfur than U.S. diesel fuel. The cleaner, Ultra-Low-Sulfur Diesel used in America does not lubricate the CP4 as well as European diesel, makes it difficult on the CP4’s hydraulic pistons to continue working, according to the experts at Diesel Army.
The CP4 also is said to struggle to supply adequate fuel to the engine under the lower pressure of these more efficient engines. The result is the formation of air bubbles inside the CP4. Air in the pump means that metal rubs against metal, causing accelerated wear. This will eventually cause the CP4 to fail, often around 100,000 miles. Before it fails, metal shavings are produced by the CP4, which travel into the fuel injectors and the fuel lines with catastrophic results.
I call BS on that. Simply not true. Since 2009, Europe uses 10 ppm ULSD. Some countries actually use lower level at 5 ppm and 0 ppm.Bosch is a European company, and Europe uses diesel fuel with more sulfur than U.S. diesel fuel. The cleaner, Ultra-Low-Sulfur Diesel used in America does not lubricate the CP4 as well as European diesel, makes it difficult on the CP4’s hydraulic pistons to continue working, according to the experts at Diesel Army.
Sulfur is not a lubricant by itself. But the process used to reduce the sulfur also reduces the fuel's lubricating properties.
