If you don't want a lot of poke, the +12's are your friend. Mine are 18x9 +18 with a 13.5" wide tire and they poke just a little. The +12's would stick out about a half inch further than mine (assuming similar tire size).Question for you all, i'm looking at some 18x9.5 wheels. They offer them with a 12mm offset or a -18mm offset. I like more of the flush look in relation to the fender flairs. Would the -18 offset poke the tires too far outside the fender flairs?
Ok thanks for the informations, the +12 it is. Nice truck btw, mine is the same colorIf you don't want a lot of poke, the +12's are your friend. Mine are 18x9 +18 with a 13.5" wide tire and they poke just a little. The +12's would stick out about a half inch further than mine (assuming similar tire size).
A -18 with that 9.5" wide wheel would stick out about an inch and a half further than mine.
it depends on what "too far" is to you. I have +18MM offset 18x9.5s on my truck right now with 37x12.5s and they stick out about an inch.Question for you all, i'm looking at some 18x9.5 wheels. They offer them with a 12mm offset or a -18mm offset. I like more of the flush look in relation to the fender flairs. Would the -18 offset poke the tires too far outside the fender flairs?
Nice! I’ll also be getting some Carli bits on mine, can’t wait to drive it. Your truck looks awesome.Got the Thuren/Carli combo installed with Fox 2.0’s and a new Fox ATS stabilizer. The 37’s have no rub, still need to install the wheel well liner modification from Ty Vole. Literally cannot believe the difference in mannerism now. Literally a night and day difference!
Where did you get the TY Vole kit? I've searched for how to order and came up short...Got the Thuren/Carli combo installed with Fox 2.0’s and a new Fox ATS stabilizer. The 37’s have no rub, still need to install the wheel well liner modification from Ty Vole. Cannot believe the difference in mannerism now. Literally a night and day difference!View attachment 54399View attachment 54400View attachment 54401View attachment 54402View attachment 54403
[email protected]Where did you get the TY Vole kit? I've searched for how to order and came up short...
Thanks man. Did it come with instructions?
You should ask what he wants for the factory beadlock rings....Bro, this mView attachment 54423
Bro, this motherfucker wants 280 for this??? He's high as ****!!
Not sure - it was sent to my shop. He should be able to tell you if it comes with instructions though.Thanks man. Did it come with instructions?
It all really depends on what value it provides and to some extent the total value of the mods being added. It’s about 1% of my total cost of mods, so it’s negligible to me. And at least after putting a lot of $$ into the truck it won’t look like Cletus took a hacksaw to the wheel well.Bro, this mView attachment 54423
Well, the rubbing has already annoyed me to the point that I ordered Method 704HD 17x9 +18mm wheels in matte black. After putting some more miles on it, I found that my first impressions were wrong. They rub quite a bit on both the sway bar and radius arm. If anyone wants to pick up some factory beadlock capable wheels near Quartzsite, AZ in the next couple weeks, I know of some that will be for sale.Toyo Open Country M/T 37x12.50 on factory beadlock capable wheels. They rub minimally on the sway bar, but not enough that I'll do anything about it.
Can you provide info on your front brush guard please. Also do you have a shot that shows the front of your truck. ThanksUpgraded to 37s today. Here is the before and after.
Went with AEV Salta rims. Can confirm they are clearing 37x12.50r17 Cooper STT Pros with ease. The tires are 13.3 inches wide by spec.
Very happy with the look of 37s on the PW. Should have come from the factory this way.![]()
I know it wasn't pointed to me, but I have the same one on order. It's from Expedition One.Can you provide info on your front brush guard please. Also do you have a shot that shows the front of your truck. Thanks
Yup....I ended up cutting part of my pinch weld and melting/reforming the plastic.Bro, this motherfucker wants 280 for this??? He's high as ****!!
