2023 HD Crowdsourced Order Tracking & Waiting Room
I believe everthing will still be built and shipped to the dealer to keep the supply train in order from collecting parts to fulfilling shipping contracts, the question is, will the newly built trucks have the good trannies or the bad ones.
This makes the most sense. Keep things moving forward. Maybe slight delay to see if they can implement a transmission fix.
Beware the tracker, just because it says doesn't make it so, at D or D1 or KZL or KZM
I have a feeling this recall will speed up the builds of AISIN orders. May get them sooner then we expect
I am guessing that is wishful thinking. I bet they continue as though nothing has changed and will let the recall happen afterwards either at the dealer or at the factory depending on where it is when they fix comes out. Personally I hope you are right as I ordered the Hemi but I doubt this will change there build sequence.
How do I find my actual build status code? I went on the live RAM chat and she only said the following:
As I've checked, your vehicle has been scheduled for production. Time in this stage varies based on your particular vehicle configuration. Once your vehicle has started production, you will see movement on the tracker! I apologize but our resource here in customer care is limited to the online vehicle order tracking system as well.
Anyway to check buildsheet? Need to double check my dealers final order into the system.
The codes that correspond to build stages in the RAM Order tracker are: C, D1 (scheduled), E (In Production), KZ (Built), KZM (Shipped), KZX (Delivered)
The order tracker is using data from this URL. Replace your Order Number and Name below to see your raw data:
https://www.ramtrucks.com/hostz/cots/order-status/<Order Number>/<Name on Order>
For Example:
Curious - in the raw data returned, is the list of options following the "sa=D28M92,2TM,21M,42E,4AK,4EA..." essentially the build sheet for the order? It sort of makes sense, but it has a few differences from what I would have expected.
It’s the sales codes, which works out to the major items that *should* end up on the build sheet. What is different from what you expected?
There are the ones that are in D1 status (assuming the sheet is correct). It would be interesting to see what if anything they have in common, like color…
Those are in D1 with all shipping details entered also, dealer, rail, truck etc.
Mine is pearl white. Also loaded it up with surround view cam etc.
Mine is Billet Silver
They need at least 10 of 1 color to run them, so there must be some commonality, might be easier to switch light colors before going to darker ones
What are estimated delivery dates??
Has anyone else not received a VIN yet? My order for a 3500 Crew DRW Laramie went in Oct 11 with Granger. No communication since.
