Do you like the Thuren Coil? I am thinking of getting these. I have the stock Bilsteins with the Off Road Group so I didn't want to lose them and get a full setup, and I didn't want a spacer. I figured adding the coil to my Bilsteins was the best method..Thuren fab!!! 2 inch coil and king shocks
Looks nice, and that weatherguard toolbox is nice too.I did an ICON 4 1/2" lift for my factory air ride Limited. Fuel Sledge 20" +20 offset with 37x 12 Ridge Grapplers. I did the Stage 4 Kit with front and rear track bars. No cutting/ trimming - very slight rubs at fuel lock due to Grappler sidelugs. Used Hypertech tuner to reset tire size. No Codes or issues. Factory air ride funtions as normal. Rides much better than stock. I got tired of waiting on the other guys: lifts for factory air ride must be the last on their lists.View attachment 3388View attachment 3389View attachment 3390View attachment 3391View attachment 3392
So sick! Man that looks good.Readylift 3"F/1"R lift, 20x9 Fuel Couplers with +1 offset on Nitto Ridge Grapplers. Zero rub. Still have to add the adjustable track bar to get the front the same on both sides. Love the ride and the look.View attachment 3402View attachment 3405View attachment 3404
How far off is the front without the front bar? Can you tell the difference?Readylift 3"F/1"R lift, 20x9 Fuel Couplers with +1 offset on Nitto Ridge Grapplers. Zero rub. Still have to add the adjustable track bar to get the front the same on both sides. Love the ride and the look.View attachment 3402View attachment 3405View attachment 3404
It was about an inch and half off. The track bar is now installed and i got it to a quarter inch difference and happy with that. Can't tell unless you pull out the tape measure.How far off is the front without the front bar? Can you tell the difference?
I did the 3/1 Readylift on my 3500. I also added Bilstein shocks, and have zero complaints about the lift... I too need to add the track bar. Which one did you install by the way?It was about an inch and half off. The track bar is now installed and i got it to a quarter inch difference and happy with that. Can't tell unless you pull out the tape measure.
