Hi all,
New to the forum, and new to Ram. We have a 39' Keystone Montana 5th Wheel which has a "shipping weight" of 13,000lbs and have hooked up with a B&W Companion 5th Wheel Hitch. We recently upgraded to the Ram 3500 (Laramie, quad cab, 4x4, dually, long bed) and were expecting effortless performance as compared to a late model Ford F350 SuperDuty that it was replacing. We live in mountainous terrain and while I can't quibble with off the line acceleration, handling, or otherwise straight line performance, we are completely underwhelmed going uphill and/or passing power. We've been towing in "Tow/Haul" mode and upon approaching hills/mountains, we find that it typically will not downshift, it'll hold approximately 26psi of boost, but we'll slowly begin to decelerate, even if I "floor it". This happened as recently as yesterday. Granted, we were at 6500' outside Mammoth Lakes, CA, but even on flatter terrain, closer to sea level, I have little confidence passing semi trucks well under the speed limit if given a 1 - 2 mile passing lane.
Is this normal? Is the power disparity between this and the High Output model that significantly different?
Thanks in advance!
Thanks in advance!
