Wheelz
I just installed this on my '22 3500. If you have ParkSense, you will need to extend the front two sensors by at least 6" otherwise your harness will not have clearance for the winch. I guess for the '22's RAM shortened the parksense harness. Also, the 2 front sensors are very sensitive to how it sits in the bumper sensor holes. The slightest misalignment will cause the sensors to constantly alert you. I also couldn't use the supplied metal intercooler shroud without significant modification of it. I just re-used the factory rubber one. I'm curious of how the intercooler guard you purchased. Please show some pictures when you get that installed. And let us know how much of a gap you have between the bumper and the body/grill. It seems for the 22's its much more than previous years. I wish AEV made a seal to cover the bumper gap. Another tip, keep everything 'snug' bolt wise for adjustment. There are so many bolts on this bumper its hard to keep track of. Use a metal marker and mark each bolt as you start to torque everything down after you have the alignment set. That center section is going to be fun with the winch inside.
The tow hook plastic bezels is just to cover the manufacturing gaps between the corners and center section and the gaps when the bull-bar gets bolted down. You'll see when you get it together.
