Thisisthe-wagon
Recommendations from anyone who has already done it. Some of the regular options seem to still be sorting there programming.
That's my exact current thought process honstly.Yeah I'm waiting for Tazer to get their act together or AEV to get some procal's in. I was going to try Alpha OBD but it seems like it's a bit of a hassle.
Its no hassle at all plus gives you a ton of other featuresYeah I'm waiting for Tazer to get their act together or AEV to get some procal's in. I was going to try Alpha OBD but it seems like it's a bit of a hassle.
I've heard it throws alot of codes etc doing the tpms and tire size for the 2022's. Also I can't seem to get any updates for it at all. I just haven't seen alot of guidance out there for the new trucks which is why I'm leary.Its no hassle at all plus gives you a ton of other features
Where did you hear it throws codes? I have yet to hear one issue that was not operator errorI've heard it throws alot of codes etc doing the tpms and tire size for the 2022's. Also I can't seem to get any updates for it at all. I just haven't seen alot of guidance out there for the new trucks which is why I'm leary.
No pin just need the bypass cableand there's no pin required on the 2022's correct? or maybe even 19 and up?
I trust a fart when im sick more than most content creators on youtube!youtube videos. But if that's the case I'll give it a go. Are the instructions for doing it the same as the other gens? I did the adjustments on an 18 and it was flawless.
I think I have to do a bit of modification to my bypass cable. shaving some key off of it. But as far as how to do the changes, is it the same as the 4th gen trucks?No pin just need the bypass cable
Check out the Alfa thread here in the modification section it has the info you seekI think I have to do a bit of modification to my bypass cable. shaving some key off of it. But as far as how to do the changes, is it the same as the 4th gen trucks?
Oh dear...never do that.I trust a fart when im sick more than most content creators on youtube!
That's the one I was talking about that I used when doing my '21One of the better videos I've found here (just make sure you're using the correct MY):
It's odd that he shows 2016 and no RF hub reset - which IS NOT required on 18+, but the process is otherwise the same.
Maybe he selected 2016 and auto-detect fixed it for him.
