Not a bash plate just an intercooler cover.
From CJC motor sports.
I really like that look. The stock air dam is pretty ugly and I was hoping there was a better option.
Lights mounted. Now just need for usps to drop off my last connectors and Amazon to deliver my mini fuse tap so I can turn them on. Not sure if I like the smoked covers. I might pull them off.
Notice any change to wind noise at highway speed? Considering the same.
Got rid of the crap Firestone tires and installed some Wildpeaks. Also replaced the chrome lugs, still can't believe Ram put chrome lugs on the Night Edition model.
Looks fantastic! Do you happen to have the manufacturer and P/N of the black lugs?
I ordered them from Driven products, the description doesn't include 2500 but they work perfect. They also have an amazon page as well.
Finished up my ‘22, 6.4 Tradesman
Falken Wildpeaks and Fuel Blitz wheels finally arrived.
Added Rough Country fender flares,
1.75” Rugged Country coil spacers,
Thuren adjustable track bar,
Timbren rear 8600lb jounce springs,
Rough Country trifold tonneau cover,
Replaced the 2500 Heavy Duty and rear rams head logo badges
with black flag badging.
In addition to the already completed leather seating, spray in bed liner, drop steps, rear wheel well liners & led headlamps.
Before:
After:
Had 35x12.5r17 Pro Comps installed. The shop shattered one of my TPMS sensors. But, should be getting that swapped out tomorrow. The shop started at door tag pressure, but I have since aired down to 50f and 45r. Tread contact looks about right, but I have not chalked it yet.
Also installed bumper plugs into the front license plate holes.
The Hillman Group 58128 3/8-Inch Black Nylon Hole Plug, 20-Pack https://smile.amazon.com/dp/B00MN6G...t_i_1301CGDZ1Z3MAREYJ7GA?_encoding=UTF8&psc=1
Finally, I installed the Kaodtech bypass. I am embarrassed to say that it took me a little bit to figure out that it was just a bridge cable across the two blocks and that any open position would work.
This weekend I will change the TPMS thresholds and change the tire size using Alfaobd.
Before:
After:
What a sharp looking ride! It's crazy how bland many trucks look before we get to make them "ours". Thanks also for the close-ups as it's great to see the black badging as I've got some ordered for my new "Whitey" and the tailgate photo helped a ton as I've got my business graphics that will cover a fair deal of real estate back there after the ram head comes off. Was the Ram head stuck on the typical tape and orientated by a pin leaving a small hole?
Thank you, it was actually fun making it mine and quite a bit less expensive than an equivalent factory upgraded model.
The head was a pain to get off, I used a heat gun to soften the “tape”, that was really about 1/16” industrial grade rubber cement that took quite a while to peel off, after popping the emblem off. There were 4 snap in clips as well.
Where did you find that bracket to mount the filter, and is that a kit? I couldn't find any for our year trucks and ended up making my own.
Stumbled across it....watched this install video and this guy named Don makes the brackets and stuff...you can contact him and buy both the mount and the bypass kit or just the mount if you will....the link to contact him is in the video description...
