brv10
has the scoop
Ram specs are normally 1.5 degrees to the right for road crown, I centered mine, drives me nuts.In the trade when doing alignments we call that slope road crown. Not much you can do about it unless you want to split the difference when doing the adjustments and even then the road crown angle can vary from interstate to interstate as far as the amount. Occasionally I got complaints and after I explained the road crown to them the customer was Ok with it. The ones that drove the interstate a lot and it bothered them, I would just split the difference to make it look half as much as it was so it looked the same whether they were driving on a road with a crown or without. In areas that get a lot of rain you are more likely to see a more radical road crown.
