mines in a PPF bubbleI use my truck as it's intended. I keep it clean as I can, but I'm not trying to have it live in a bubble.
I literally felt the punch to my stomach looking at that picture...I let mine drink.
Looks Awesome! The Patriot Blue has a huge amount of color shift depending on the lighting and always looks amazing!Did the ceramic coating on the paint today.
The Mopar mud flaps better get here quick, I found 2 chips already with 90 miles on it.
I also need to order the vent visors. Window tint in a week. December 16th is Krown rust proofing ($160).![]()
Looks good enough to eat!Did the ceramic coating on the paint today.
How did you adjust the threshold? AlphaOBD? Tazer?Today I adjusted my TPMS threshold down to 45psi because I was sick of my light on the dash after just a day or two.
I keep my tires at 55 psi but it got cold enough for them to read 51 psi and that triggered the light for the rear tires and prompted the truck to demand that I inflate to 65psi to turn it off.
I use my AEV pro cal, it’s super easy to use.How did you adjust the threshold? AlphaOBD? Tazer?
The sport package looks better with the blue. Big blue whale.Did the ceramic coating on the paint today.
I let mine drink.
Some may wonder why I chose 45 psi if I run 55psi. Well, I need to run 49psi to match my gvwr with these tires but the tires I want to get (soon? maybe?) will require only 42psi to carry the same weight (I’ll probably run 45) so I was just future proofing my settings.
So the Pro Cal will do that? Earlier today in a FB group a member was saying the instructions said he needed to visit the dealer after programming the TPS to get it to stick. I told him to go find a buddy with an AlfaOBD and bypass cable. Maybe I should have just told him to read the instructions better! LOL
No, its actually a 1 ton diesel Bronco. I built it about 12 years ago.Is that a 3/4ton diesel bronco?
Procal snap works perfectly on they 19+ models, this one is different than the older model, my understanding is the older models had an issue. My pro cal changed tire size and tire pressure, also can set the gearing if yo change that. I haven'tSo the Pro Cal will do that? Earlier today in a FB group a member was saying the instructions said he needed to visit the dealer after programming the TPS to get it to stick. I told him to go find a buddy with an AlfaOBD and bypass cable. Maybe I should have just told him to read the instructions better! LOL
Any idea if Uconnect 5 would effect this product working or not on the 2022 models?Procal snap works perfectly on they 19+ models, this one is different than the older model, my understanding is the older models had an issue. My pro cal changed tire size and tire pressure, also can set the gearing if yo change that. I haven't
