Well again, for the record, I have an AA relay with tape on the back. It passed the temp test, but they still put RTV on the back of it. Whether that is wrong or right, is a separate question, but that’s what happened for me yesterday.So if we have an after 1/08/21 truck with the AA relay with the tape and it passes the temp test then nothing more is done. This, even though to the eye at least, both the RTV and the AB solution looks like they are better. That makes me think that maybe the current recall actually has nothing to do with whatever is or is not on the back of the relay. They may be looking only for some sort of electrical problem in the relay itself. And they must feel if a relay tests OK, it is safe and will never develop a problem. Or maybe the problem is with the exposed back of the relay but they feel that if an AA with the tape tests OK, that tape is a good fix and there is no need to remove the tape and apply RTV. Just a guessing game for us trying to figure it out I suppose.
I have the same relay with tape and as long as they removed the tape first, I would rather have done what you got. Not just "passed the test, good to go". Somehow it just seems to me that RTV on the back is better than a piece of tape even if the truck passed the test. Although I suppose a person could RTV it themselves if they wanted.Well again, for the record, I have an AA relay with tape on the back. It passed the temp test, but they still put RTV on the back of it. Whether that is wrong or right, is a separate question, but that’s what happened for me yesterday.
Yeah, I almost did it myself, but I figured I’d have them do it for warranty purposes.I have the same relay with tape and as long as they removed the tape first, I would rather have done what you got. Not just "passed the test, good to go". Somehow it just seems to me that RTV on the back is better than a piece of tape even if the truck passed the test. Although I suppose a person could RTV it themselves if they wanted.
I think that is best. I was just thinking about someone who has the AA relay with tape and a good test. Some read the recall as saying in that situation nothing gets done, You just go home with the same taped over relay. If that happens to me, I would consider doing the RTV myself. Unless that is by that time there is a reason known to not do it. Or maybe in a month or two we will know for sure one way or another if there is going to be a whole new relay. I am just glad I don't live in Northern Idaho or someplace where it gets cold so I can just leave it disconnected for now.Yeah, I almost did it myself, but I figured I’d have them do it for warranty purposes.
The combination of passing the temp test and more than 600 hours suggests that the failure happens in the first few hundred hours of operation so if you are over 600 hours the failure will not occur. The temp test is designed to catch either an abnormal temperature rise or max temp. It sounds like some of the AA units have a manufacturing problem that results in the overload condition.Yes, the temperature test is the new "solution".
Not if you disconnect it from the battery-
When I had mine disconnected from the battery, I made sure to double tap the press to start button all the time. Not sure if that made the difference.Interesting because that is all and exactly what I did? In fact the photo with the pencil pointing to the disconnecting place that Brutal_HO put on the first post is my photo. Today I got a CEL and code P2609 which searching online and my Banks iDash both tell me is abnormal voltage detected in one of the air intake circuits. That makes sense I guess, as disconnected, that relay circuit would have no voltage. Strange though that no others have had this happen.
If you only pressed the start button once and the truck started, then maybe temps were above the 41 degrees it was when I started mine. I have noticed that sometimes, usually when the truck is warm, pressing once starts the truck. But more often, especially first thing in the morning, and before I disconnected the relay, I would press start once leaving my foot on the brake and the pre-heat countdown would occur. After it finished the truck would start on its own. This time I pressed just once, the countdown occurred and the truck did not start on its own. I suspect this is because the temp was low enough so it wanted the pre heat before starting. So I pressed the button a 2nd time at that point, forcing a start and perhaps that is what caused the CEL.I have had my relay disconnected for about two weeks, and driven about 4 times since then. Each of those times would have included two or three restarts. Only once did I do a double-tap of the start button. Also, I have seen the "waiting-to-start" timer come on a couple of times. My truck is garaged when not driven and the temps have been mild all that time. So far, I have not had any lights come on and everything seems normal. My truck is a 2021 HO with either a March or April build date.
Hmm, that seems to throw out my and cycling4life's theory. I don't know what to think if, after the relay was disconnected, you had the truck do its diesel pre-heat countdown and then start on its own without a second press of the button. In my case the diesel pre-heat countdown definitely occurred but the truck did not start until I pressed the start button again. I noticed the CEL after driving about 1/2 mile but that only means that is when I noticed it. It may have come on right then or when the truck started, I don't know.I would guess the temps were always in the low 50's or above. Also, when the pre-heat timer did come on, the truck always started on it's own once the timer was finished.
So if correct I wonder if remembering the double tap would avoid it or not? Seems odd that I am the only one who has reported it so far.I have read elsewhere that the battery current sensor detects the lack of current draw during start and throws the code as a result.
Are you brave enough to let it count down and try to start on its own without a 2nd press? (Just kidding, leave well enough alone!)I’ve been double-tapping the start button every single time with my relay disconnected from both the battery and the heater, but connected to the small control wire. My CEL has never come on.
