toyboy1980
So the deal is if you have the AA revision it just gets sealed on the back with RTV.Just pulled mine to look. Here’s what I’ve got. Truck was built 4-21.
Now the question is…do I just leave this thing unhooked until further notice?
Gotcha. I mean, do I just seal it up with RTV myself, or let a dealer do it?So the deal is if you have the AA revision it just gets sealed on the back with RTV.
And then your sent on your way.
Call spelled out in the document listed under the Google drive up above somewhere in the thread
Take it to the dealer because that version is good as long as it gets sealed based on what their document says. And then you get warranty coverage for the repairGotcha. I mean, do I just seal it up with RTV myself, or let a dealer do it?
Yes scroll up through this thread and you will see the inspection criteria. Of course they are out of stock because they cannot order the replacement part until they have tested or inspected the one in the vehicle. It is all spelled out in that document link above. I would really like it but I'm on my phone and it's complicatedI have an appointment to have mine in for the recall in a little over a week.
I would think that if some dealers are showing that the relay is out of stock, they would at least be able to test the one in the truck to know if it needs replacing or not.
That said, this all has me wondering if it is at all possible to retrofit to the old style relay that worked just fine. Something tells me the signal wires to activate the relay are much smaller on the new relays though, and not built to activate an older style relay.
If something should go wrong nobody will back your six....Ram and the insurance company would love to blame you and not pay for a crispy critter Ram.Gotcha. I mean, do I just seal it up with RTV myself, or let a dealer do it?
Yes, my thought was just that by disconnecting the relay we are invalidating the engine hours parameter in the recall instructions as it relates to hours on the relay.
Also it was said in an earlier post that the waiting for the preheat portion of the relay/grid heater usage is a small percentage of the time it is working. Supposedly it cycles on and off as you are driving as long as ambient air temp is below a certain level.
anyone has the steps to properly disconnect the relay without throwing codes? Pics would be nice too
There is info about that in this thread and in the other on the same subject. I am about to do mine. As I understand it, just remove and tape up the wire from the relay at the battery. Supposedly it does not throw any codes. Someone posted yesterday that he has driven many miles with it disconnected and all is good so far.anyone has the steps to properly disconnect the relay without throwing codes? Pics would be nice too
Oh my dealer says the parts are in stock and I'm scheduled to go in. I just meant for those that are saying their dealers are having them wait to perform this recall that doesn't make sense to me, even if they don't have parts on stock if that makes sense. Just trying to make a suggestion to help others.Yes scroll up through this thread and you will see the inspection criteria. Of course they are out of stock because they cannot order the replacement part until they have tested or inspected the one in the vehicle. It is all spelled out in that document link above. I would really like it but I'm on my phone and it's complicated
Yeah agreed. I unhooked it for now, and made an appointment for next week.If something should go wrong nobody will back your six....Ram and the insurance company would love to blame you and not pay for a crispy critter Ram.
Exactly what I did. I have an appointment next week, but I’m not taking any chances until then. I just wrapped up the connector (cut the finger off a nitrile glove), and zip tied it to the other cable so it doesn’t flop around. I’ll undo that right before I take it in to the appointment.There is info about that in this thread and in the other on the same subject. I am about to do mine. As I understand it, just remove and tape up the wire from the relay at the battery. Supposedly it does not throw any codes. Someone posted yesterday that he has driven many miles with it disconnected and all is good so far.
Yes.Is the relay actually defective or is the concern that the exposed relay terminals will short out on the frame or mounting surface? Mine has yellow tape applied to the back and was built on February 28, 2021. The earlier recall consisted of applying RTV over the exposed terminals. Either tape or the application of the RTV leads me to suspect that an exposed terminal on the back of the relay might contact the frame. I took mine out the other day but really didn't take note of the mounting surface.
