DeepH20Driller
Looks like it has Level C and tons of other options
Good call. There are 4 within 30 miles of me. All tradesman. Guessing they must be in transport.So, just curious, I went to Cars.com and searched for 2022 Ram 2500 with a nationwide search area. Over 130 come up. I only tried 5 of the serial numbers that pop up, but here’s a Big Horn that a dealer in Wisconsin is advertising
I’m outta here. This thread has become pathetic. Give me a call when trucks start showing up on lots. The amount of bitching and whining on here is comical. So thanks for the laugh
8/20 is correctThe only number I could see being manufactured date
Above the bar code there is a S.L number and like the one below its go a 4 digit number example "0820" August 20thwhere does it say manufacture date on window sticker?
That is same window sticker as one of members posted here earlier. Thought it was his unit?Just a little bit of info I reached out to a company claiming they have a 2022 in transit at Harry Brown family automotive is Fairbault MN. Claims for a 1000 deposit can reserve it once it comes in with a ETA of 9/4 to 9/17 go check it out for yourself attached is the window sticker. This is a positive
Ping @22Tradesman as it's his VIN. I assume you're still planning to take delivery of your truck?That is same window sticker as one of members posted here earlier. Thought it was his unit?
Yes that's the correct date....usually not saying that's the case here with all the craziness with this years start up production. That circled date is either the date the truck was built or the day the sticker was printed to be placed on the truck (and sometimes both). To verify this when you @22Tradesman get the truck match that date to the door sticker that shows the Month, Day, Hour MDH on the sticker to see the exact date it was built.The only number I could see being manufactured date
That is the build date,checked it in DC,built in hour 12Yes that's the correct date....usually not saying that's the case here with all the craziness with this years start up production. That circled date is either the date the truck was built or the day the sticker was printed to be placed on the truck (and sometimes both). To verify this when you @22Tradesman get the truck match that date to the door sticker that shows the Month, Day, Hour MDH on the sticker to see the exact date it was built.
Have there been any other Trucks built from the crowdsourced tracker that have window stickers?That is the build date,checked it in DC,built in hour 12
OkI’m outta here. This thread has become pathetic. Give me a call when trucks start showing up on lots. The amount of bitching and whining on here is comical. So thanks for the laugh
That is same window sticker as one of members posted here earlier. Thought was his uni
I was planning on picking it up still lolYes that's the correct date....usually not saying that's the case here with all the craziness with this years start up production. That circled date is either the date the truck was built or the day the sticker was printed to be placed on the truck (and sometimes both). To verify this when you @22Tradesman get the truck match that date to the door sticker that shows the Month, Day, Hour MDH on the sticker to see the exact date it was built.
If you are getting a diesel you might want to go with a 3500. The payload on a 2500 takes a serious hit with the diesel, it gets down to around 2000 - 2200 LBSI'm about to pull the trigger on a new order. Dealer is giving me a great figure for my 2018 Ram 2500 Mega loaded Big Horn Can you guys give me your input on build?
2022 Ram 2500 Mega Big Horn
2HZ - Diesel
-Level B pkg (There was a level C package listed when I was at the dealer on Sat, would not open specs due to system slowness)
-Big Horn Silver Edition
-Tech Pkg
-5th wheel prep grp
-Off road pkg
-Bucket seats
-Spray liner/bed lights (cheaper to go w bed utility grp?)
-220 amp
-Cab lights
-Rear wheel liners
More cost effective to go with Laramie? Leather seats aren't a must. Any other pkg I should look at?
